Mobile (android/iOS) clients suddenly lose connection
  • 1.  Mobile (android/iOS) clients suddenly lose connection
    Posted Oct 12, 2017 03:49 AM
    Dear all experts and friends,
    Our wlan has serious trouble with all mobile devices ( Android/iOS)
    Aruba infratructure
    Controller : 7205 version 6.4.4.9 ( Master-local)
    IAP 325: converted to campus AP mode
    Radius: Cisco ACS 4.5 (802.1x) ( staff)
    Internal database: for Guest access
    MAC authentication: for deverloper
    03 SSID: staff,dev,guest
    1. All laptop user now have good connection to wlan ( all SSID)
    2. Mobile user (android) cannot access staff's wlan (802.x1), if they can, they will be disconnected after a few seconds
    3. Mobile user can normally access wlan dev and guest without disconnecting (non-802.1x)
    4. i've already removed 802.1x authentication (staff) and use preshared key.after that, mobile client can normally access it.
    5. Mobile user can normally access wlan ( staff dot.1x) with Ruckus system.
    6. i've already removed cisco ACS and use NPS ( radius microsft) but mobile client disconnected after few seconds or mintues or they cannot access. ( same cisco ACS)
    I dont think this is error on mobile devices, because mobile user can normaly with other WLAN ( ruckus, free wifi, home, cafe...)
    In attached file :
    Log mobile client when access my Aruba WLAN ( failse)
    Log mobile client when access my Aruba WLAN ( success)
    Log laptop client when access my Aruba WLAN ( Always success)
    In log failse, i saw after send authentication, controller provided vlan for client, but client cannot got IP address.
    I was spend alot of time (two week and more), but i cannot detect the root cause.
    Dear all experts and friend , please help me to investigate the proplem, Please review my configuration and give me some ideas or recommend for me.
    Thank you so much
    Best and regards,
    Lee Nguyen
  • 2.  RE: Mobile (android/iOS) clients suddenly lose connection
    Posted Oct 16, 2017 09:36 AM
    hi Lee
    Reproduce the issue then collect "show auth-tracebuf" shortly thereafter. Then, connect with the working laptop and run "show auth-tracebuf" again. (you may wish to enter "no paging" first to make it easier to collect, also ensure that "show running-config | include user-debug" returns no output first, e.g. there should be no user-debug configured)
    Double check that you have the correct forwarding mode on the dot1x enabled virtual-ap profile.
    what is the configuration of role wlan_high_priority-role ?
