mobileip logs with IP Mobility disabled
  • 1.  mobileip logs with IP Mobility disabled
    Posted Feb 02, 2015 11:51 AM
    I set a user-debug for a specific user and see messages like this:
    Feb 2 12:36:26 :500402:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Receive Delete User from Auth, proxy mobile prev state MIP_PROXY_CREATE_SIBYTE_BRIDGE_NOMOB_TEMPORARY current state MIP_PROXY_NO_MOBILITY_SERVICE delete reason Delete reason code not set
    Feb 2 12:36:26 :500079:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Initiating Proxy mobile (current state MIP_PROXY_NO_MOBILITY_SERVICE, prev state MIP_PROXY_CREATE_SIBYTE_BRIDGE_NOMOB_TEMPORARY) delete reason  Roaming Status: No Mobility service
    Feb 2 12:36:26 :500001:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Mobile IP PROXY finite state machine event RECEIVE_AAA_DELETE: current: MIP_PROXY_NO_MOBILITY_SERVICE, next: MIP_PROXY_DELETE_SIBYTE_BRIDGE
    Feb 2 12:36:26 :522005:   |authmgr|  MAC=84:38:38:32:d4:36 IP=192.168.64.77 User entry deleted: reason=idle timeout
    Feb 2 12:36:26 :522050:   |authmgr|  MAC=84:38:38:32:d4:36,IP=N/A User data downloaded to datapath, new Role=BCB_Vap_Movel/48, bw Contract=0/0,reason=Station resetting role
    Feb 2 12:36:26 :522038:   |authmgr|  username=dmc-t061991646469 MAC=84:38:38:32:d4:36 IP=192.168.64.77 Authentication result=Authentication Successful method=radius-accounting server=radius_bcb_vap_movel_sbcdf046
    Feb 2 12:36:26 :500045:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Removed bridge entry for local station on vlan 64; ingress interface: tunnel 28
    Feb 2 12:36:26 :500001:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Mobile IP PROXY finite state machine event RECEIVE_SIBYTE_SUCCESS: current: MIP_PROXY_DELETE_SIBYTE_BRIDGE, next: MIP_PROXY_DELETE_SIBYTE_HOME_BRIDGE
    Feb 2 12:36:26 :500001:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Mobile IP PROXY finite state machine event RECEIVE_SIBYTE_SUCCESS: current: MIP_PROXY_DELETE_SIBYTE_HOME_BRIDGE, next: MIP_PROXY_DELETE_VERIFY
    Feb 2 12:36:26 :500001:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Mobile IP PROXY finite state machine event RECEIVE_REPLY_SUCCESS: current: MIP_PROXY_DELETE_VERIFY, next: MIP_PROXY_INIT
    Feb 2 12:36:26 :500990:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: proxy mobile node deleted code 0x2000000 reason
    Feb 2 12:36:26 :500424:   |mobileip|  Station 84:38:38:32:d4:36, 192.168.64.77: Sending notification MIP_IGMP_CLIENT_LEAVE flags 0, roaming state No Mobility service, current vlan 64 ingress tunnel 28 to pim
    But this Virtual AP is set with no IP Mobility.
    Why controller generates log of type [mobileip] for VAPs without IP mobility?
  • 2.  RE: mobileip logs with IP Mobility disabled
    Posted Feb 02, 2015 11:54 AM
    Are you having any issues?
    Are you using any multicast services?
    Tim
  • 3.  RE: mobileip logs with IP Mobility disabled
    Posted Feb 02, 2015 12:28 PM
    No issues.
    We don't use multicast services.
    This is an old installation (4 years old) made by a Aruba's partner and all controllers are configured with this:
    router mobile
    ip mobile domain default
    ip mobile proxy stale-timeout 3600
    ip igmp
    But our 3 VAPs don't use IP Mobility and these [mobileip] logs is flooding our logs with not useful information, I think.
  • 4.  RE: mobileip logs with IP Mobility disabled
    Posted Feb 03, 2015 10:35 AM
    Try:
    no router mobile
     ..to turn it off globally...
  • 5.  RE: mobileip logs with IP Mobility disabled
    Posted Feb 03, 2015 11:39 AM
    I will try this and look the logs.
    Thank you.
  • 6.  RE: mobileip logs with IP Mobility disabled
    Posted Nov 03, 2017 11:15 PM
    if you disable the mobileip global, does there has the mobileip logs ?
