last person joined: 11 hours ago
mobility between two controller cluster
  • 1.  mobility between two controller cluster
    Posted Dec 11, 2013 11:17 PM
    i have two aruba controller cluster in two differnet building. both two cluster are in Master/Local(active/passive) model.
    now these two builging are connect to a large building, so we have a project to set a roaming between this two cluster controller.(from buliding A to building B and vise)
    as there are two different clients subnet on each side, so i need to enable the L3-mobility between these two cluster ?
    or do i add the same building A vlans on controllers to building B controllers to do a L2 mobility??
    what is my decision should i concern or care about on ?
    which mobility model should i perfrom??
    all help are very appreciate..
    arubafresher
  • 2.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 07:10 AM
    Since you have two different Master-local clusters, I would enable L3 mobility for these clients.
  • 3.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 07:10 PM
    Can you give a deeper explanation, Seth?
  • 4.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 07:37 PM
    I would configure L3 roaming (IP Mobility) between these buildings vs. adding VLANs to both sides.  This is covered in our user guide but a basic config (in 6.3) would look like this...
    ip mobile domain CampusXYZ
       description <description>
       hat 172.16.100.100 description "Bldg1 ihome agent"
       hat 192.168.100.100 description "Bldg 2 home agent"
  • 5.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 07:47 PM
    Right. but he does not define VRRP. souldnt he have that first? :)
    or am i way off?
    edit: nwm. he does. sorry :fool's errand)
    active\passive
  • 6.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 07:57 PM
    YOu don't need VRRP between these buildings
  • 7.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 08:03 PM
    nahh . not between the buildings. just in the cluster.
    ? or
  • 8.  RE: mobility between two controller cluster
    Posted Dec 12, 2013 08:55 PM
    dear Seth Fiermonti,,
    many thanks for soon reply...
    controller A is in building A
    controller B is in building B
    one more question for L3 mobility. if i associate with AP_a in building A,i will go though controller A to internet....now i am going to building B....i will asoociate another AP_b on building B and the roaming is occured... the whole path is " Controller B -> Controller A -> internet"...Controller B and Controller A will form a mobility tunnel and i don't lose my original IP get from building A. do my concept right?
    if the above concept right...but my goal is when i go to building B....i don't want the traffic go back to building A then go to internet. how can i do? so , i dont need mobility , right ? if i don't want lose my original IP...should i need create vlans same as the Building A to do a L2 mobility..???
    many thanks,
  • 9.  RE: mobility between two controller cluster
    Posted Dec 13, 2013 05:04 AM
    yes. :)
  • 10.  RE: mobility between two controller cluster
    Posted Dec 16, 2013 10:41 PM
    any limitation of the l3 mobility between two controller? my controller model is 7200 series...
    how many concurrent roaming user/serssion support?? assume that my building at most 5000 people will use wifi and walk across two building...
  • 11.  RE: mobility between two controller cluster
    Posted Dec 19, 2013 04:37 AM
    There wont be 5000 users roaming :)  I think you will be good to go.
  • 12.  RE: mobility between two controller cluster
    Posted Dec 19, 2013 02:48 AM
    hi Seth R. Fiermonti
    the <hat agent ip> should be in the loacl controllers which under the same master controller???
    thx a lot..
