Have you checked to see what vmnic is mapped to the vSwitch in use by the virtual machine on the hypervisor side?
Dustin Burns
Senior Mobility and Access Engineer @WEI
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
Original Message:
Sent: Sep 14, 2021 09:53 AM
Subject: Mobility Conductor (Mobility Master) default interface change
I'm setting up a Virtual Mobility Conductor and running into an issue with the default interfaces of GE 0/0/0 and GE 0/0/1 are automatically using a NIC that I didn't assign. On the server I'm using I have a 10G connection for other VM's and two 1G ports I want to use for the Mobility Conductor. However it's defaulting to the 10G connection and I need to know if there is a way to change that?
Chris Smith
