You Can directly upgrade to 8.10.0.8 from 8.6.0.22...
This communication is intended only for the person or entity to which it is addressed and may contain confidential information. Any form of unauthorized review, retransmission, dissemination, other use or action taken in reliance upon this information, by any other than the intended recipient may be unlawful and is prohibited. If you received this in error, please contact the sender and delete the material. Whilst reasonable care has been taken to avoid the transmission of viruses, the recipient must ensure that the transmission, opening or use of this message and any attachments will not adversely affect its systems or data.
🌍 Please consider the environment before printing this email.
Original Message:
Sent: 2/25/2024 2:39:00 AM
Subject: RE: Mobility Controller
Thank you for your reply.
Is there any upgrade path? I am checking the release notes but am not able to find anything related to this matter.
Eyad Subeh
Original Message:
Sent: Feb 25, 2024 02:32 AM
Subject: Mobility Controller
8.10.0.8 would be good fit
Original Message:
Sent: 2/25/2024 2:31:00 AM
Dears,
Hope you are all doing well,
We have a Mobility controller in version 8.6.0.22, and we want to upgrade it to the most stable version since 8.6 is EOS.
Could you please advise me on which version should I upgrade to?
Thank you.
Eyad Subeh
