Mobility Controller 3400 configuration / routing
  • 1.  Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 03:33 PM
    Hi.  I’m hoping someone can help me with some configuration issues.
    I’m attempting to set up an environment with an Aruba Mobility Controller 3400 running AOS 6.3.0.1 with 18 AC-225 WAPs.  I have a Fortigate 600C serving as my firewall/router and a Windows Server as my DHCP server.
    My issue is that I’ve got my mobility controller hooked up to my network and have all of my WAPs on a single VLAN, which connect to the controller.  I’ve got the WAPs connected to the controller on port 1 (on VLAN 700) and have port 2 set up as a trunk line back to the switch (which has a trunk to the router).  Currently, I’ve got an WLAN set to attach clients to VLAN 100.  I can connect to that WLAN, but don’t receive a DHCP address after connecting.  Manually setting an address that is part of VLAN 100 while connected to the WLAN, I can connect to the mobility controller, but can’t reach anything else.
    I know there’s probably a simple solution here, but I’m struggling to find it.  Thanks for any help you can offer!
    #3400
  • 2.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 04:26 PM
    Please run show ip route  and show ip interface brief
  • 3.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 04:30 PM
    show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
           M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 10.0.90.1 to network 0.0.0.0 at cost 10
    S*    0.0.0.0/0  [10/0] via 10.0.90.1*
    C    10.0.90.0/24 is directly connected, VLAN700
    C    10.1.0.0/24 is directly connected, VLAN1
    C    10.0.0.0/20 is directly connected, VLAN100
    C    10.0.254.0/24 is directly connected, VLAN2000
    C    10.0.100.0/22 is directly connected, VLAN1000
    C    10.0.120.0/24 is directly connected, VLAN900
    C    10.0.50.0/24 is directly connected, VLAN200
    C    10.0.60.0/24 is directly connected, VLAN300
    C    10.0.80.0/24 is directly connected, VLAN800
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 700                   10.0.90.254 / 255.255.255.0     up      up
    vlan 1                      10.1.0.254 / 255.255.255.0     up      up
    vlan 100                      10.0.0.3 / 255.255.240.0     up      up
    vlan 2000                 10.0.254.254 / 255.255.255.0     up      up
    vlan 1000                 10.0.100.254 / 255.255.252.0     up      up
    vlan 900                  10.0.120.254 / 255.255.255.0     up      up
    vlan 200                   10.0.50.254 / 255.255.255.0     up      up
    vlan 300                   10.0.60.254 / 255.255.255.0     up      up
    vlan 800                   10.0.80.254 / 255.255.255.0     up      up
    loopback                    unassigned / unassigned        up      up
    mgmt                        unassigned / unassigned        down    down
  • 4.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 04:44 PM
    1- What you need to do is create a trunk and add all the VLANs to the same trunk ?
    2- Is this your uplink switch 10.0.90.1 ? You may have to change the default gateway if your internal routing doesn't allow you to reach VLAN 100 through VLAN 700 ? right now all your traffic is going through that.
    3- Do you have an IP Helper address configured on the Layer 3 VLAN 100 on the uplink side of things? What are you using HSRP or VRRP ?
  • 5.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 04:49 PM
    1. Trunk set up is below, I'm using GE1/2 for the trunk currently.
    show trunk
    Trunk Port Table
    Port Vlans Allowed Vlans Active Native Vlan
    GE1/2 ALL 1,100,200,300,700,800,900,1000,2000 700
    GE1/3 ALL 1,100,200,300,700,800,900,1000,2000 700
    2. For VLAN 700, the gateway is 10.0.90.1.  Internal routing allows VLAN 700 to talk to VLAN 100.
    3. I do have IP Relay set on the Layer 3 device for VLAN 100.  I'm not sure if it is HSRP or VRRP.
    Thanks for your assistance so far!
  • 6.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 05:09 PM
    Did you created a port-channel ? Because I see you have two trunks ? if you don't have a port-channel configuration this could a potential issue .
  • 7.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 05:22 PM
    I did not create a port-channel.  I was not using more than one trunk at a time.  Had tried them on different native VLANs (one at a time, not simultaneously).  I've disabled one of the trunks now, and still have the same issues.
  • 8.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 05:25 PM
    Please do a traceroute from the controller to the VLAN 100 Layer 3 on the uplink side
    Can you also try to ping it
  • 9.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 05:27 PM
    Make sure that the native VLAN matches on both sides
  • 10.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 20, 2013 09:39 PM
    I can't ping or get a traceroute through to the other side of the L3 device.
    Currently, my trunk connection from the mobility controller goes into a port with the same native VLAN on one of the switches (Aruba S2500) which has its own trunk port to the L3 device.  I realize this is probably where the problem lies.
    If so, and I use the following layout, am I still going to be able to properly handle my wired traffic from my switches:
    VLANS (Wired switches and Wireless WAPs)  --->  Mobility Controller ----> L3 device?
    Thanks.
  • 11.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 21, 2013 09:39 AM
    So your s2500 is just simply a l2 device ?
  • 12.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 21, 2013 11:33 AM
    Correct - it's a stack of 8 S2500s which all provide level 2 switching.
  • 13.  RE: Mobility Controller 3400 configuration / routing
    Posted Sep 22, 2013 09:31 PM
    Victor,
    Thanks for taking a look.  I ended up getting it to work by taking a trunk line (native VLAN 700) from the switch stack into a trunk port on the 3400 and used a second trunk port (native VLAN 700) on the 3400 to connect to a port on the L3 device, and I'm now getting both DHCP access and access to the internet.
    Thanks again for your help.
