You responded to a very old post, which means that things are probably very different. Memory usage is not necessarily a problem by itself; memory will be used for caching purposes instead of left unused; please reach out to Aruba Support if you have any doubt or create a new post with more details (version, device type, actual data) to ask the question for your situation.
Original Message:
Sent: Aug 01, 2023 06:06 AM
Subject: Mobility Controller 7220 Memory usage is too high
How did this problem end up? Is it resolved? I am currently facing this problem too, high mem and high storage.
Original Message:
Sent: Mar 30, 2018 07:46 AM
Hi all,
I've set up 2 MCs 7220 in a cluster, clients are about more than 2500.
Memory usage of these MCs is always high
Today when I wrote a configuration, at that time the free memory was 45MB, and the authentication module was restarted. All clients are disassociated.
Did anyone have the same problem?
