MOBILITY controller setting for voice
  • 1.  MOBILITY controller setting for voice
    Posted Mar 11, 2014 05:36 AM
    hello Airheads,
    our customer would like to deploy a mobile phone app to use the wireless infrastructure (2.4GHZ\5GHz).
    They already have an Aruba WLAN (MOBILITY CONTROLLER) and would like to know how they can ensure
    good QOS and traffic prioritization for the phones running this app. It is the Shoretel communicator app and the
    voice gateway i believe will be hosted local to the site.
    Thanks in advance Pete
  • 2.  RE: MOBILITY controller setting for voice
    Posted Mar 11, 2014 08:04 AM
    If I understand this correclty, app is basically a VoIP softphone.
    Therefore you canrefer to the "Voice over IP (VoIP) Deployment with Aruba Mobility Access Switch application note" when setting up the network.
    The practices in this appnote should applicable to the VoIP traffic from that smartphone app, just the same as from any other VoIP client.
    You can find the document here: http://www.arubanetworks.com/wp-content/uploads/VoIPwMASAppNote-20120726.pdf
  • 3.  RE: MOBILITY controller setting for voice
    Posted Mar 11, 2014 08:26 AM
    thanks for reply not really what i am looking for.
    I am looking for a start to finish set up on an Aruba controller to include the ssid settings in the vap,
    WMM through to the DSCP settings. I have been through the controller user guide but i was just wondering
    if a design ref guide was available.
    cheers
    Pete
  • 4.  RE: MOBILITY controller setting for voice
    Posted Mar 11, 2014 05:33 PM
    The link made above is likely the best source short of manually peicing the parts you need together out of the UG. WMM, DSCP, etc are all covered there.
  • 5.  RE: MOBILITY controller setting for voice
    Posted Mar 20, 2014 11:41 AM
    you guys sure the read the document? it is mainly about how to connect wired voip phones, there really is nothing on DSCP, WMM, and wireless things for voice.
  • 6.  RE: MOBILITY controller setting for voice
    Posted Mar 25, 2014 09:16 AM
    spend some more time collecting info (see below), the high level principles are clear, would be nice to have some specific tips and caveats.
    voice on RAPs (title says controller, but chapter 2 clearly says Best Practices for Voice Deployment at Remote Sites):
    http://www.arubanetworks.com/wp-content/uploads/VoiceSupportAppNote_2011-11-14.pdf
    voice on wired networks (mainly on detecting phones and setting up pc behind phone):
    high level VoWLAN document:
    http://www.arubanetworks.com/pdf/technology/TB_Voice-Over-WLAN.pdf
    table 19 in this document comes the closest to actual "configure these" advise:
    http://www.arubanetworks.com/vrd/80211nNetworksVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap6_WiFiMultMedia.html
    this is probably a very useful document if you were at the session, now it again points to things but without the context it is difficult to judge the exact actions needed:
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/AirheadsConf-LV-2013-Breakout-Wireless-LAN-Optimizing-Wi-Fi-for/ta-p/69758
    were those break out sessions taped?
    serie of 4 best practices information (high level, no config) from 2011
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-1/ta-p/16473
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-2/ta-p/16475
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-3/ta-p/16479
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Best-Practices-for-Voice-over-Wi-Fi-Part-4/ta-p/16481
    serie of 4 planning information (high level, no config) orginally from 2007
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-LAN-Planning/ta-p/25698
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Wi-Fi-Coverage/ta-p/25700
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Quality-of/ta-p/25702
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Checklist-for-Planning-a-Voice-Over-Wi-Fi-Network-Security-and/ta-p/25704
  • 7.  RE: MOBILITY controller setting for voice
    Posted Feb 27, 2018 10:44 AM
    No Ducuments within this article works.  Has Aruba given up on the VoWLAN?  Are they doing something different?  I know that most of the docxuments on this page do not work...
  • 8.  RE: MOBILITY controller setting for voice
    Posted Feb 27, 2018 12:11 PM
    Which voice device are you using?  Those links are pretty old and technology moves pretty fast.
  • 9.  RE: MOBILITY controller setting for voice
    Posted Feb 27, 2018 12:21 PM
    GM,
    I am using the 7205 Controller, with 79 AP's(215).  Wanted to allow VoWLAN and then maybe intergrate to the Softphone application.  Wanted to read up on best practices and configuration so that I may try a test with my system.  Yet all the links I have tried only send me to "Nothing Found"  Is there anything out there to assist me in using VoWLAN?  Just found the equipment listing.  http://community.arubanetworks.com/t5/Wireless-Access/Wireless-Phones/td-p/63532
  • 10.  RE: MOBILITY controller setting for voice
    Posted Apr 04, 2015 05:46 AM
    All the links given below are broken. Can the fresh links be refreshed concerning this problem statement.
  • 11.  RE: MOBILITY controller setting for voice
    Posted Apr 04, 2015 09:41 AM
    All the links in the post right above yours work.  Which link are you referring to?
    Alternatively, you can do a search for anything related and should be able to find what you want.
