Mobility Controller
  • 1.  Mobility Controller
    Posted Feb 25, 2024 02:31 AM
    Dears,
    Hope you are all doing well,
    We have a Mobility controller in version 8.6.0.22, and we want to upgrade it to the most stable version since 8.6 is EOS.
    Could you please advise me on which version should I upgrade to?
    Thank you.
    Eyad Subeh
  • 2.  RE: Mobility Controller
    Posted Feb 25, 2024 02:33 AM
    8.10.0.8 would be good fit
    This communication is intended only for the person or entity to which it is addressed and may contain confidential information. Any form of unauthorized review, retransmission, dissemination, other use or action taken in reliance upon this information, by any other than the intended recipient may be unlawful and is prohibited. If you received this in error, please contact the sender and delete the material. Whilst reasonable care has been taken to avoid the transmission of viruses, the recipient must ensure that the transmission, opening or use of this message and any attachments will not adversely affect its systems or data.
    🌍 Please consider the environment before printing this email.
  • 3.  RE: Mobility Controller
    Posted Feb 25, 2024 02:39 AM
    Thank you for your reply.
    Is there any upgrade path? I am checking the release notes but am not able to find anything related to this matter.
    Eyad Subeh
  • 4.  RE: Mobility Controller
    Posted Feb 25, 2024 02:41 AM
    You Can directly upgrade to 8.10.0.8 from 8.6.0.22...
  • 5.  RE: Mobility Controller
    MVP
    Posted Feb 25, 2024 02:13 PM
    Before upgrading, please check the AP OS Matrix.
    We had clients who did self upgrades from previous versions and there was no support for the Old Access Points which they had.
    Shpat | ACEP | ACMP | ACCP | ACDP |
    -Just an Aruba enthusiast and contributor by cases-
