Mobility master as a service provider
  • 1.  Mobility master as a service provider
    Posted May 23, 2020 11:08 AM
    Hi, as a system integrator, can i use a mobility master to manage a lot of my customer MD ?
    Thanks a lot
  • 2.  RE: Mobility master as a service provider
    Posted May 23, 2020 12:37 PM
    Although the MM provides centralized management for multiple controllers, it is not designed for this use case especially if you have different customers. There is no "multi-tenancy" in MM..
    If you are considering to build an MSP solution, you might want to consider Aruba Central. You can align with your Aruba SE to build a better solution..
  • 3.  RE: Mobility master as a service provider
    Posted May 25, 2020 01:17 AM
    but aruba central can manage only instant ap, not controller
