last person joined: 7 hours ago
Mobility master HA upgrade
This thread has been viewed 21 times
  • 1.  Mobility master HA upgrade
    Posted May 09, 2023 04:24 PM
    We have an active and backup mobility master, and I am having trouble accessing the backup mobility master from the active MM. My question is if I upgrade the AOS from 8.7.1.7 to 8.10.0.5 on the active MM, do I also need to manually upgrade the backup MM, or will it be done automatically when MM1 is upgraded?
    My second question is whether it is possible to access the backup MM. Thank you for your assistance.
  • 2.  RE: Mobility master HA upgrade
    Posted May 09, 2023 05:08 PM
    You will have to update both MM's individually.
    Yes, you should be able to access the GUI or SSH of the backup at anytime.
    If it is serving as the backup, the session should start with a banner telling you that configuration is limited.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
