Mobility Master hardware installation weird issue
  • 1.  Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 05:53 AM
    I am in the position of installing, 2 * Mobility Master (10K) hardware devices and 5 * 7200 Controllers.
    The installation of the MM hardware appliances was looking good until, command line looked normal for OS8 can see
    (GCC-DV-MM-01) [mynode] #cd /mm
    (GCC-DV-MM-01) [mm] #
    , ( I have already setup a test lab using virtual versions of the MM and WLC using OS8 prior to this install)
    I logged into the web gui and i found an unusual issue, one of the MM seems fine as expected but the other MM has the same gui presentation as a WLC. see screen shot.
    Is this a build issue? wrong licenses added in production
    Dave Stalker
  • 2.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 05:56 AM
    Did you try clearing your browser cache?
  • 3.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 06:15 AM
    The browser works fine with the other MM? and I only noticed there was an issue when i typed
    show license passphrase
    and it said command unsupported, i was consolled onto the device?
    thanks for your swift reply
    Dave
  • 4.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 08:00 AM
    sorry not a browser caching issue im afraid
    thanks
    Dave
  • 5.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 08:12 AM
    Please open a support ticket so that it can be looked at:
    http://www.arubanetworks.com/support-services/support-program/contact-support
  • 6.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 09:39 AM
    Hi!
    The "Command is not supported for this platform" when you issue
    *[mynode] #show license passphrase is expected when you run on a hardware mobility master.
    It really looks like if your browser still has things cached for that particular IP/hostname. Have you tried CTRL+F5 and other browsers?
    Do you have both MM setup in redundancy now? What does "show switches" and "show switchinfo" from your MMs tell you?
    Cheers,
  • 7.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 10:30 AM
    The device i am installing is a hardware device so should be a useable command?
    Sorry i tried that no luck, also if it cached it from a previous controller would it update the name and the hardware version? and the other MM works fine and dandy ?
    is there a way to blank the hardware device and build it from scratch, using ova, iso file?
    thanks
    Dave
  • 8.  RE: Mobility Master hardware installation weird issue
    Posted Jul 02, 2018 02:35 PM
    I saw this recently and after restarting the MM it was fine..didnt get a chance to open a case tho.
    Are you using any APs that required 8.3.x ? or particular feature in 8.3.0?
    If not i recommend to go with 8.2.1.1 instead
  • 9.  RE: Mobility Master hardware installation weird issue
    Posted Jul 03, 2018 03:11 AM
    Thanks for that i shall give it a try, unfortunately it shall not be until next week installed in a new Data Centre with no remote access! looong story lol
    I shall also bare in mind the OS recommendation just went for the latest one as that is just about always the first thing TAC case say are to blame but a rollback might be worth a shot also
    thanks again
    Dave
  • 10.  RE: Mobility Master hardware installation weird issue
    Posted Jul 18, 2018 06:34 AM
    Thanks all,
    The Device just needed a manual power down and everything was fine, just a glitch in the matrix
    thanks
    Dave
