Mobility Master in Cloud
This thread has been viewed 22 times
  • 1.  Mobility Master in Cloud
    Posted Aug 01, 2022 01:18 PM
    I know i posted this question a couple years ago but would like to check if there is any update :)
    I have a VMM running OS 8.6.0.16 in the datacenter, is it possible to move it to AWS or Azure? if No, is there a future plan to have that ability or I have to plan implementing Central instead?
    Appreciate your help,
    Husam Yaqoob
  • 2.  RE: Mobility Master in Cloud
    Posted Aug 08, 2022 07:35 AM
    You can check the supported platforms for VMM here. If you can run ESX/HyperV/KVM VMs in your cloud provider, it may work.
    For roadmap/future plans, please reach out to your local Aruba account team as these plans cannot be discussed in public.
