Mobility Master Licensing
  • 1.  Mobility Master Licensing
    Posted May 12, 2017 10:27 AM
    I need to clarify MM Licensing: If I have 10 MC and  2000 AP  running 6.x and i now migrate to 8.1
    In 6.x I have 2000 AP-Lic
    When I now migrate to 8.1 and the MM is only to configure the MC and will not terminate any AP how much/which Lics I need to add?
    I thought I have to add 10 extra Lics for the 10 MC and migrate the 2000 AP-Lic to run on the MM.
  • 2.  RE: Mobility Master Licensing
  • 3.  RE: Mobility Master Licensing
    Posted May 15, 2017 03:01 AM
    thank you, this made it clear:
  • 4.  RE: Mobility Master Licensing
    Posted Jan 26, 2018 12:38 AM
    agree, the screenshot answered my question too.
  • 5.  RE: Mobility Master Licensing
    Posted Mar 13, 2018 10:05 AM
    Just a quick quest regarding the MM-VM.
    If I wanna do failover netween MM I will need to purchase basically double MM-VA-250 for each device.
    Meaning 2 MM for 250 Devices for HA eqauls 2X250 MM-VA-250 Correct?
    Regards
  • 6.  RE: Mobility Master Licensing
    Posted Mar 13, 2018 10:12 AM
    How many devices are you looking to manage via the MM ?
    APs and Controllers?
  • 7.  RE: Mobility Master Licensing
    Posted Mar 13, 2018 10:32 AM
    It will start of with 180AP's and 2 MC running in HA and room for growth on the AP's.
    Regards
  • 8.  RE: Mobility Master Licensing
    Posted Mar 13, 2018 11:54 AM
    There is no 250 AP MM.  Do you plan Master/standby (layer2 redundancy) or primary/secondary (layer3 redundancy)?
    For Layer2 redundancy I think you need
    1x MM-VA-500  (install it twice for Master/Standby)
    180x LIC-AP
    Service and maybe 180x PEF, 180x RF-Protect , ...
  • 9.  RE: Mobility Master Licensing
    Posted Mar 13, 2018 12:00 PM
    i attached a screenshot with 4 MM:  primary active/standby + secondary active/standby which terminate only MC.
    For that setup with 500AP i wanted to clarify the licensing:
    2x MM-VA-500 (for standby just install it twice?)
    1000 Lic AP  (500 for primary and 500 for secondary)
    can somebody confirm that?
