Mobility Master - Managed Device - Show configuration
  • 1.  Mobility Master - Managed Device - Show configuration
    Posted Feb 22, 2018 05:05 AM
    I would like to see the running configuration of the Managed Network Group, any way to see this?
    If i navigate in cli to /md/GroupName/ and do a show configuration, it just gives me the config of the /mm/ node.
    As i need to do a lot of similar creation of Roles, Policies, AP Groups, Authentication servers / groups, etc. it would be preferable to do this via cli.
    Regards
    Kevin
  • 2.  RE: Mobility Master - Managed Device - Show configuration
    Posted Feb 22, 2018 06:17 AM
    Hi Kevin,
    have you tried show configuration effective?
    You go to cd /md/YOUR_GROUP and run the command.
    Also, you can do show ap-group ? and it will show you all the AP groups in the GROUP. Same with other profiles like SSID, AAA, VAP's, etc.
  • 3.  RE: Mobility Master - Managed Device - Show configuration
    Posted Feb 22, 2018 06:22 AM
    Hi Borja,
    That worked! Thanks a bunch for the quick reply :)
  • 4.  RE: Mobility Master - Managed Device - Show configuration
    Posted Feb 22, 2018 04:43 PM
    You can also try 'show configuration committed' to see the non inherited configuration of that folder.
    #AirheadsMobile
