Mobility Master - User-Role name in uppercase
  • 1.  Mobility Master - User-Role name in uppercase
    Posted Sep 12, 2017 08:35 AM
    I just started a new Mobility Master VM appliance and when I add new User-Role, the names are automatically converted in lowercase.  I tried using Web GUI and CLI and it is the same.
    Am I missing something or is it a bug?
    Version: MM VM 8.1.0.2
    Browser: Firefox and IE (both latest version)
    Thank you,
  • 2.  RE: Mobility Master - User-Role name in uppercase
    Posted Sep 12, 2017 08:38 AM
    This is normal behavior in 8.X. Everything will be normalized to lowercase.
  • 3.  RE: Mobility Master - User-Role name in uppercase
    Posted Sep 12, 2017 08:44 AM
    Hello Tim,
    thanks for the ultra quick answer :)
    No problem for me if it is the new way but if ClearPass is sending the role name with uppercase, will the systems convert it automatically or do I need to modify it in ClearPass?
    By the way, the MM 8.1.0.0 user guide is not yet modified to reflect this: on page 79, they use the commands:
    (host) [mynode] (config) #user-role THR-ROLE-NAME-WPA2
    access-list session THR-POLICY-NAME-WPA2
  • 4.  RE: Mobility Master - User-Role name in uppercase
    Posted Sep 12, 2017 08:51 AM
    The controller will normalize all VSAs returned from ClearPass to lowercase. So user-role “MEDIA-PLAYER” will automatically be interpreted by the controller as “media-player”.
  • 5.  RE: Mobility Master - User-Role name in uppercase
    Posted Sep 12, 2017 08:54 AM
    ok, thanks
  • 6.  RE: Mobility Master - User-Role name in uppercase
