Mobility Master VRRP on vlan 1
  • 1.  Mobility Master VRRP on vlan 1
    Posted Jun 17, 2019 02:37 PM
    I have a mobility master using an access port, which is therefore vlan 1 from the perspective of the MM. It doesn't seem to be possible to configure VRRP on vlan 1. The GUI complains about using vlan1 (only vlan there is) the CLI does not. But it doesn't work. The MM can ping itself on the VRRP address, but nothing else can.
    I've found documentation, albeit from an earlier version of AOS8, that shows vlan1 being used.https://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/VRRP/Redundancy_Parameters.htm
    I've used
    vrrp 88
    ip address <ip>
    authentication <password>
    vlan 1
    no shutdown
    Should this work?
  • 2.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 01:36 AM
    Hardware or VMM?
  • 3.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 04:29 AM
    VMM
  • 4.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 05:15 AM
    Hi Matthew Seymour
  • 5.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 05:58 AM
    Yep, I've done exactly that... Just doesn't work.
  • 6.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 06:05 AM
    On submit I get a warning the vlan is invalid. The config will apply, and I can see it in the CLI - all looks fine, but it doesn't work. The VRRP address exists in the box (so to speak) the MM can ping itself on that address, but it doesn't get attached to the vlan and make it onto the wire.
    This must be something to do with the network setup for the MM, that I've done wrong... but I don't know what.
  • 7.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 07:21 AM
    can you check VLAN tag id in mgmt interfaces?
    And which AOS version are you using?
  • 8.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 07:28 AM
    Hi Mathew,
    It seems like a warning. Try deploying the changes and then check if VRRP is up or not?
  • 9.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 08:02 AM
    Yeah, this thread is because it doesn't work.
    The VRRP IP is pingable from the MM itself, but it doesn't make it out onto the wire.
  • 10.  RE: Mobility Master VRRP on vlan 1
    Posted Jun 18, 2019 09:50 AM
    FOUND IT!!!!!!
    It looks like the warning is incorrect. That's what threw me.
    The problem is our VM infrastructure has promiscuous mode denied. Hadn't twigged this because I don't get to setup anything on VMware.
    Thanks all
  • 11.  RE: Mobility Master VRRP on vlan 1
    Posted Jan 10, 2020 09:54 AM
    I'm getting the same warning invalid vlan with  hardware mobility masters not using vlan 1 either. I have one vlan created for the controller IP of each MM and the controller IP is in /24 different IP's. I still get this warning the vlan is trunked though a port channel I'm using ports 0 and 1.
  • 12.  RE: Mobility Master VRRP on vlan 1
    Posted Jan 10, 2020 10:37 AM
    That doesn't seem related to the Op's VM issue.  I would open a separate thread with your specific details.
