Wired Intelligent Edge
Mobility Switch
  • 1.  Mobility Switch
    Posted Jun 26, 2014 01:03 PM
    I have a design question.  I have a customer that would like to install the Aruba switches in tunneled node.  However, they would like to have it where if the master controller failed it will just operate like a L2 switch.  Is this supported?  If so how would you go about programming such a setup?
  • 2.  RE: Mobility Switch
    Posted Jun 26, 2014 01:05 PM
    John,
    That is not currently supported.
    You can have a backup controller configured or point the TN ports to a VRRP address of a controller pair.
    Best regards,
    Madani
  • 3.  RE: Mobility Switch
    Posted Jun 26, 2014 01:39 PM
    Okay. That is what I thought but before I told the customer no I wanted to check. Thank you for responding!
