Model APIN315, OS 6.5.3, disable SSL on internal splash, allow whitespace in splash
  • 1.  Model APIN315, OS 6.5.3, disable SSL on internal splash, allow whitespace in splash
    Posted Aug 28, 2017 04:54 PM
    I want to configure a standalone IAP with an internal non SSL acknowledgement page. Is this possible? If not, please consider this a feature request.
    Please also allow for whitespace in the splash page.
  • 2.  RE: Model APIN315, OS 6.5.3, disable SSL on internal splash, allow whitespace in splash
    Posted Aug 29, 2017 08:52 AM
    The internal splash page on Aruba Instant is very basic. If you need such features, you likely better use an external web server for hosting the web page, which provides all design features that you can imagine (and can create the HTML/CSS for).
    If you need such a feature built into the product, please contact your local Aruba SE to have a request for enhancement filed for these features. In that way, the idea will be evaluated for future product version.
