modulation used by client transmit power control and AP usage
  • 1.  modulation used by client transmit power control and AP usage
    Posted May 03, 2014 02:22 PM
    We are doing testing for Multicast over wireless ( without DMO) need help understanding below points
    1. Can we check the current modulation type the client is using ? ( MCS index or something similar)
    2.Usage details of AP / radio . Specifically from CLI.
    3. Is automatic transmitt power control is available for both uplink and downlink?
  • 2.  RE: modulation used by client transmit power control and AP usage
    Posted May 03, 2014 02:28 PM
    1. Can we check the current modulation type the client is using ? ( MCS index or something similar) - A wireless packet capture is the most accurate means to reveal the MCS rate of every frame.  Anything on the controller will just be a snapshot in time MCS (statistics might only be updated every 60 seconds).
    2.Usage details of AP / radio . Specifically from CLI. - show ap debug radio-stats ap-name <name of ap> radio 0 advanced should give you all the radio stats of the AP.
    3. Is automatic transmitt power control is available for both uplink and downlink? - Please be more specific
