Module Authentication is busy. Please try later
This thread has been viewed 31 times
  • 1.  Module Authentication is busy. Please try later
    Posted Nov 09, 2012 05:32 PM
    I am getting the following error:
    Save failed: Module Authentication is busy. Please try later
    Usually if I wait a bit I can save my running config or do a show run.
    It has been 2 days now that we cannot save the running config or do a show run.
    Controller: 3200 (no memory expansion module)
    AOS: 6.1.3.3
    What can I do without rebooting the controller? There are some config changes we need saved, and I can't pull them from the show run as it does not work either.
    #3200
  • 2.  RE: Module Authentication is busy. Please try later
    Posted Nov 10, 2012 12:51 AM
    can you use TFTP to save it in your PC ?
    is it the same thing happening with WebUI ?
    did you try to use the console ?
  • 3.  RE: Module Authentication is busy. Please try later
    Posted Nov 10, 2012 01:21 AM
    console isn't working.
    Last time I used TFTP with this controller, I had to reboot it as a result.
    I will try to ship the running config over FTP
  • 4.  RE: Module Authentication is busy. Please try later
    Posted Nov 10, 2012 12:55 PM
    can you try #show cpuload
  • 5.  RE: Module Authentication is busy. Please try later
    Posted Nov 12, 2012 08:32 AM
    (multi-poc-wips-wlc-1.c6.dv) #show cpuload
    user 0.3%, system 0.2%, idle 99.6%
    (multi-poc-wips-wlc-1.c6.dv) #show memory
    Memory (Kb): total: 354128, used: 314592, free: 39536
  • 6.  RE: Module Authentication is busy. Please try later
    Posted Nov 15, 2012 07:27 PM
    So i moved the entire config off the 3200 and onto a 3600, transfered the licenses, the whole kit
    I am now getting the error again.
    Could it be something in the configuration?
  • 7.  RE: Module Authentication is busy. Please try later
    Posted Nov 15, 2012 07:40 PM
    There are a number of reasons why this would happen.  Please open a tac case so that they can get to the bottom of it.
  • 8.  RE: Module Authentication is busy. Please try later
    Posted Nov 16, 2012 08:05 AM
    Thanks. I just did. Let's see what they say.
