Monitor my VIA users bandwidth usage
  • 1.  Monitor my VIA users bandwidth usage
    Posted Mar 16, 2020 07:57 AM
    Got a working solution with VIA client on my network; the controllers are monitored in Airwave
    I want to monitor the individual users and see who’s using what bandwidth. I checked airwave on the controller supplying VPN capability. It has a bit that says how many VPN users there currently are - but says its 0 / zero. I know for a fact there’s lots on there.
    does anyone know if I need to do something else to monitor this statistic?
  • 2.  RE: Monitor my VIA users bandwidth usage
    Posted Mar 17, 2020 05:07 AM
    So I’m looking in the mobility master and I can only see how many connected clients there are - not any individual bandwidth information.
    I'm guessing this is the first place to start? If I get that information to display in the mobility master, maybe Airwave will catch on?
  • 3.  RE: Monitor my VIA users bandwidth usage
    Posted Mar 17, 2020 10:20 AM
    What version is the MM and what version are your MDs?
  • 4.  RE: Monitor my VIA users bandwidth usage
    Posted Mar 17, 2020 10:28 AM
    Got a virtual MM on version 8.4.0
    got two x 7210 controllers on version 8.4.0
  • 5.  RE: Monitor my VIA users bandwidth usage
    Posted Mar 17, 2020 10:31 AM
    There are many bugs with ArubaOS 8.4.0.0 and it is end of life, and it is not being patched anymore so I would expect that seeing incomplete statistics on the MM are one of them.
    https://www.arubanetworks.com/support-services/end-of-life/#ArubaOSSoftware
    I would consider upgrading to the latest 8.5.x.x or 8.6.x.x if you have 802.11ax access points in the future to fix that.
