Wired Intelligent Edge
Monitor used memory in CX using SNMP
This thread has been viewed 61 times
  • 1.  Monitor used memory in CX using SNMP
    Posted Jan 14, 2023 05:31 PM
    I'm unable to locate an OID that allows me to monitor memory usage in Aruba CX switches over SNMP.
    None of the standard OIDs in HOST-RESSEOURCES works on a CX-6100
    Where can I find these OIDs? I can't snmpwalk my way to them, and I cant find it the downloaded MIB library for Aruba CX.
  • 2.  RE: Monitor used memory in CX using SNMP
    Posted Jan 14, 2023 05:53 PM
    Did you try to check https://www.arubanetworks.com/techdocs/AOS-CX/10.10/HTML/snmp_mib/Content/Chp_MIB_sppt/new-int-mib-tra.htm ? The table arubaWiredSystemInfoTable in ARUBAWIRED-SYSTEMINFO-MIB contains:
    arubaWiredSystemInfoMemory OBJECT-TYPE
    SYNTAX Unsigned32 (0..100)
    MAX-ACCESS read-only
    STATUS current
    DESCRIPTION "The memory usage of subsystem in percentage."
    ::= { arubaWiredSystemInfoEntry 4 }
    You need 10.10.xxxx s/w installed on your 6100 to have this object available.
    Ivan Bondar
  • 3.  RE: Monitor used memory in CX using SNMP
    Posted Jan 14, 2023 07:02 PM
    Thanks mate. I will give it a spin to see what that reports. In the mean time I got some data out of HOST-RESSOURCES on memory. I had a config error in my Zabbix template. However - the switch dashboard says 29% memory utilisation - the SNMP Query says 38%... Wonder what that is about.
  • 4.  RE: Monitor used memory in CX using SNMP
    Posted Jan 15, 2023 04:57 AM
    The dashboard's CPU report shows current average CPU utilization. It should correlate with the 'CPU Util %' parameter in the output of 'show system' command. Could you check if both give you similar values? I am asking to understand where we have this discrepancy - between web ui/cli and snmp or between web ui and snmp/cli. Also could you clarify which object from HOST-RESOURCES MIB do you monitor?
    Ivan Bondar
  • 5.  RE: Monitor used memory in CX using SNMP
    Posted Jan 15, 2023 08:45 AM
    Hi Ivan
    The CPU usage between UI, CLI and SNMP correlates just fine. It's memory utilisation that's misreporting (in my config) over SNMP - UI and CLI agree on 29% percent utilization. The switch is a CX-6100 v.10.10.1020 and I'm using the standard Zabbix HOST-RESSOURCES MIB now, and monitoring the discovered memory from there (discovery[{#MEMNAME},1.3.6.1.2.1.25.2.3.1.3,{#MEMTYPE},1.3.6.1.2.1.25.2.3.1.2,{#ALLOC_UNITS},1.3.6.1.2.1.25.2.3.1.4]). The built in calculation returns 38% used from the Memory Used out of Memory Total.
  • 6.  RE: Monitor used memory in CX using SNMP
    Posted Jan 15, 2023 10:14 AM
    Sorry, my bad, I got another question about CPU utilization and both got mixed in my head :)
    Those OID 1.3.6.1.2.1.25.2.3.1.* seem to be for storage, not for memory.
    Ivan Bondar
  • 7.  RE: Monitor used memory in CX using SNMP
    Posted Jan 15, 2023 10:46 AM
    Yeah that was also my first thought (even though it is meant to be for memory).
    But the CLI command "sh system ressource-utilization all" shows storage as 64% full on the switch, so that is even further away from the SNMP output.
  • 8.  RE: Monitor used memory in CX using SNMP
    Posted Jan 15, 2023 07:36 AM
    Hello, I would like to ask how to enable snmp on the switch, I want to monitor my switch and AP on ariwave platform
