Monitoring down Access Points through Controller with SNMP
  • 1.  Monitoring down Access Points through Controller with SNMP
    Posted Oct 10, 2016 09:15 AM
    Dear Community
    According to this article https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/548 I should be able to get the number of down APs. But when I walk through the MIB there we're no results found. I want to monitor if an AP gets down.
    To show the total number of APs that are down:
    snmpwalk -v 2c -m ALL -c <snmp community name> <Master controller IP
    addr> .1.3.6.1.4.1.14823.2.2.1.1.3.4.1.6 | grep 'INTEGER: 2' |wc -l
    The CLI equivalent of this command is "show ap global-list location 0.0.0". (In ArubaOS 3.x, it is "show ap database inactive".) This SNMP poll must be run against the Aruba Master Controller.
    Kind Regards
    Marc
  • 2.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Oct 25, 2016 09:16 AM
    Now I am trying to monitor down APs by reading the REST API XML File which contains all APs in a list. I don't know if the controller also provides this function but in my case I try with AirWave.
    Link to XML: https://airwave/ap_list.xml
    I created a Javascript which parses the XML and checks for each down AP.
    Problem: To get the XML file there's a login required. It's not a basic HTML Login.
    Does anybody know if there's a possibility to access the XML without a login? Scheduled task on AirWave?
  • 3.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Oct 25, 2016 09:26 AM
    Unfortunately, there is not a known way around this.  It might be a security issue if that was available.
  • 4.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Oct 26, 2016 04:53 AM
    How would you monitor your Accesspoints?
  • 5.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Oct 26, 2016 04:59 AM
  • 6.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Oct 27, 2016 02:06 AM
    Allright I knew there are options like this.
    We are working with an external monitoring tool (WhatsUp Gold). We're monitoring our customers infrastructure and if a device gets down we get an SMS alert. There are customers without AirWave. Thats why I have to bring the information to our monitoring tool.
  • 7.  RE: Monitoring down Access Points through Controller with SNMP
    Posted Feb 14, 2017 09:46 AM
    Does anybody know a solution to monitor down APs through controller using snmp?
