Network Management
Monitoring ssids through airwave
  • 1.  Monitoring ssids through airwave
    Posted Feb 21, 2013 02:44 AM
    Hi All,
    Need to monitor the ssids configured in several aruba controllers in our campus through the airwave.Need to know is it possible to configure the alerts in the airwave like -if clients try connecting to a ssid and fails.The monitoring should be like if any ssid misbehaves or clients cannot connect to ssid we should get a alert in airwave which can trigger mail to me.Please suggest
  • 2.  RE: Monitoring ssids through airwave
    Posted Feb 21, 2013 03:39 AM
    • If you are using using Radius in order to Auth your clients - u can trigger e-mail alert on any auth issue of client.
    • You also can build a trigger to notify u whenever users/client are suffering from low speeds/godhood.(it might give some idea regarding users that will suffer from connectivity issues)
    Regarding to know if and how clients are using your ssid - u can build a report (hourly or daily)
    That the way's that i was monitor my ssid/auth problem.
    Attachment(s)
    pdf
    1.pdf   562 KB 1 version
  • 3.  RE: Monitoring ssids through airwave
    Posted Feb 21, 2013 08:30 AM
    kdisc - which of those options would work for question posted?  I don't see one specific to ssid's not working or clients not able to connect to a ssid.
  • 4.  RE: Monitoring ssids through airwave
    Posted Feb 21, 2013 09:52 AM
    I Re-edit my answer,after reading his question,and as always i'm, trying to give as much tips and ideas - sometime users find a solution in one of my tips.
    But thanks for fixing my mistake. (i answered to the post in a very late night :) and answered on auto-mode )
    and also the guy wrote: "Please suggest"
    have a lovely evening.
    me
  • 5.  RE: Monitoring ssids through airwave
    Posted Feb 22, 2013 08:57 AM
    No worries Carlos. I was just checking to see if you had a solution and I missed it in your original post.
