More than 10 Destinations in AppRF Report?
  • 1.  More than 10 Destinations in AppRF Report?
    Posted Feb 16, 2016 11:06 AM
    we use the AMP 8.0.10 with Instant Config. Is there any opportunity, to show more then 10 destinations for one WLAN in a report?
    If I choose AppRf on the menue, I can see more than 10 destinations, but if I want to create an AppRf report, I can only choose the template "Top 10 destinations". My target would be, to create a daily report with all destinations for one special WLAN and then to export this report as a CVS to a FTP Server.
    Thanks...
  • 2.  RE: More than 10 Destinations in AppRF Report?
    Posted Feb 17, 2016 09:48 AM
    Have you tried generating an AppRF report?  In this report's definitions, you can specify a number for the topN applications.
  • 3.  RE: More than 10 Destinations in AppRF Report?
    Posted Feb 17, 2016 12:15 PM
    Thanks for the hint, but i have already 4 different WLAN's and need explcit from one WLAN the destinations.
    If i try to restrict my report for one WLAN, the report shows always the destinations from the 4 WLAN's without a restriction.
