More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
  • 1.  More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Aug 19, 2013 02:22 PM
    I have an IAP 93 running 6.2.1.0-3.3.02 and I would like to set it up as a DHCP server.
    I know I can set up the main DHCP Server pool on System > DHCP
    But I would like one SSID to be assigned a range of IP address, and another one a different range. For example:
    - SSID 1 should use DHCP Scope 10.103.1.0/24
    - SSID 2 should use DHCP Scope 10.103.2.0/24
    I've tried using the More > DHCP Server and tried creating both Distributed Layer 3 and Other modes, assigning the pool to a vlan and then selecting the vlan on the SSID configuration, but I haven't been successful,
    What would be the procedure for setting up more than one DHCP pool and then assigning it to an SSID?
  • 2.  RE: More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Aug 20, 2013 03:29 PM
    That is not suported.  The More --> DHCP settings have to do with IAP + VPN functionality.  You are limited to one scope and that scope is ONLY assigned to SSIDs set to "Virtual Controller Assigned" for IP addressing in the VLAN tab settings.
    I recommend an external DHCP server for your scenario.  An Aruba switch (with a ton of IAP integration like auto VLAN config and Rogue AP Wired correlation) can also function as a DHCP server.
  • 3.  RE: More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Aug 29, 2013 05:23 PM
    Thanks Seth! We are going to use an external DHCP server instead.
  • 4.  RE: More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Oct 05, 2013 09:58 PM
    by defining a LOCAL scope under DHCP servers, you can now specific a specific block if addresses to assing on a per SSID basis. Note that your VLAN assignment needs to be NETWORK when establishing the SSID parametres.
  • 5.  RE: More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Oct 05, 2013 11:05 PM
    Put up a simple IAP Guest Network to denote that we can define local DHCP pools, have the VC assign them and tag to the SSID in question.
    wlan ssid-profile IAP-Guest
    enable
    index 0
    type guest
    essid IAP-Guest
    opmode opensystem
    max-authentication-failures 0
    vlan 15,16
    auth-server InternalServer
    rf-band all
    captive-portal internal
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    ip dhcp IAP-Pool
    server-type Local
    server-vlan 15
    subnet 192.168.15.0
    subnet-mask 255.255.255.0
    ip dhcp IAP-Pool2
    server-type Local
    server-vlan 16
    subnet 192.168.16.0
  • 6.  RE: More than one DHCP pool with Aruba Instant 6.2.1.0-3.3.02
    Posted Jul 08, 2014 06:33 AM
    What is the maximum dhcp scope supported?
    Is it 512 addresses on IAP? (Y/N) ___
