More than one Guest Network
  • 1.  More than one Guest Network
    MVP
    Posted May 03, 2022 02:37 AM
    I´m looking for a solution, to create two different guest networksm both for wired and wireless use.
    On the wireless side, I assume I could create two different SSIDs and create two self registration pages in ClearPass. But I´m afraid all registered users will have access two both networks.
    And I have no idea how to impelement this on the wired side...
    Any thoughts on this?
    Matthias Pohl
  • 2.  RE: More than one Guest Network
    Posted May 03, 2022 07:08 AM
    Start here for wired guest:  https://asp.arubanetworks.com/downloads/documents/RmlsZTpmMDY3Y2UwYS1lNmZiLTExZWEtYjFjMi0zYmZjN2Y0MzMxNDI%3D
    Do you want your guests to ONLY have access to wired OR wireless?  I want to understand your concern.
  • 3.  RE: More than one Guest Network
    MVP
    Posted May 03, 2022 07:17 AM
    They should have access to both wired and wireless.
    I´ve already implemented this for one single guest network. Now I´m looking for a way how to setup a second guest network.
    Thx. for the link to the solution guide. I´ll check it.
    Matthias Pohl
  • 4.  RE: More than one Guest Network
    Posted May 03, 2022 07:26 AM
    If you are using the same guest database, guest credentials that work on the wireless network should work on the wired network.  The only difference is that a device that has a wired and wireless card will have different mac addresses and will be seen as a different device, so mac caching will not work between wired and wireless, but the credentials will work.
