more than one virtual controller on the same vlan?
  • 1.  more than one virtual controller on the same vlan?
    Posted Mar 22, 2016 07:11 AM
    If you are using IAPs on a virtual controller configuration, Could I have severals virtual controllers in the same vlan? And if it posible..Do you recommend it?
    I´m not sure if it possible but I think that it´s not a good practise, I wolud like have a management vlan for each virtual controller, but I need confirm this information.
    Regrads!!!
    EF
  • 2.  RE: more than one virtual controller on the same vlan?
    Posted Mar 22, 2016 07:12 AM
    Is not possible
