Motorola WiNG 5.x Radius CoA doesn't work
  • 1.  Motorola WiNG 5.x Radius CoA doesn't work
    Posted Oct 05, 2017 10:39 AM
    Hi
    I'm trying to integrate Motorola Controller WiNG 5.x with Aruba ClearPass OnGuard.
    As I have learned this controller support Radius CoA as for example we can see here:
    http://wirelesssolutions-blog.blogspot.com/2014/02/wing-radius-attributes.html
    I have configured SSID with 802.1x and enabled dynamic vlan feature, that seems works ok, then I have tried to terminate session via Radius CoA. Authentication works ok. SSID in tunneled.
    I have enabled Radius Dynamic Authorization option under Advanced of WLAN settings.
    I have tried built in Motorola enforcement profile and some other, also send Radius attribues as in above link (1, 31, 44)
    But still without success.
    Can someone help ? Has anybody similar problem ?
    I'm not very fluent on Motorola solution, but already works some time on it
    Regrds
  • 2.  RE: Motorola WiNG 5.x Radius CoA doesn't work
    Posted Oct 05, 2017 10:47 AM
    What is shown on the CoA tab in access tracker?
  • 3.  RE: Motorola WiNG 5.x Radius CoA doesn't work
    Posted Oct 05, 2017 11:31 AM
    Hi
    What do you mean by CoA tab ? sorry but I can't find it.
    You mean Radius response under Output TAB ?
    regards
    Karol
  • 4.  RE: Motorola WiNG 5.x Radius CoA doesn't work
    Posted Oct 05, 2017 11:39 AM
    After manually issuing a DM/CoA from access tracker, a CoA tab will appear on the initial request.
  • 5.  RE: Motorola WiNG 5.x Radius CoA doesn't work
    Posted Oct 05, 2017 12:05 PM
    ok, thank you
    It seems that now it works :)
    Your guides led me to solution, but it is not clear for me
    One issue:
    When I try to make CoA manualy I can do it only for one Enforcement profile (drop down list: Radius CoA Type) although I have couple of it.
    When I have changed this profile to work with Motorola (1,31 and 44) and added it to policy, It stareted to work
    Why it is so ?
    I forget about something ?
    regards
    Karol
