Mounting AP-205 vertically
  • 1.  Mounting AP-205 vertically
    Posted Oct 03, 2016 01:06 PM
    Hello all,
    What are the implciation of mounting the AP-205 / IAP-205 vertically? The APs will be about mounted about 8 feet from the floor.
  • 2.  RE: Mounting AP-205 vertically
    Posted Oct 04, 2016 02:16 AM
    Based on the internal antenna orientation (downtilt), 205 is optimized to be used in horizontal mounting. If you use it vertically, the antenna coverage pattern will mostly be covering the base and top of AP which may not be useful for you.
    You can look at Installation guide (link below) to get more idea
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=14545
