Mounting AP-215 and 225 to a standard "single gang" junction box?
  • 1.  Mounting AP-215 and 225 to a standard "single gang" junction box?
    Posted Jan 22, 2016 08:34 PM
    This is way basic, but, can I use a AP-220-MNT-W1 to put a 215 or 225 on an existing junction box? We will be doing a new roll out of Aruba gear, replacing old Juniper wifi, and most of the locations are drop ceilings, but a few have conduit to junction boxes on the ceilings. From the template, it looks like the -W1 mount has holes in the right places.
    Yet, only the instructions for the "secure" version of the mount, the -W2, show mounting on a junction box:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17223 )
    The -W1 instructions don't show anything but a straight wall mount. Is there some reason it doesn't work well on a junction box?  ( https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11536 )
    Or, more generally: is there any difference between the -W1 and the -W2 versions aside from the security enclosure feature? Can I use either one for a basic single gang box?
    Thanks for any clues!
    Steve
  • 2.  RE: Mounting AP-215 and 225 to a standard "single gang" junction box?
    Posted Jan 22, 2016 10:34 PM
    The W1 mount will not mount to a standard single gang box.   The 2 holes in the center of the mount are too close.   And the 4 corner holes are too far apart.    The W2 does mate up fine with a single gang box.
