Mounting AP-220s and AP-320s to unistrut.
  • 1.  Mounting AP-220s and AP-320s to unistrut.
    Posted Oct 21, 2015 01:00 PM
    Hi everyone,
    New to Aruba equipment. Some of my indoor areas the only place to mount the AP is on unistrut. Has anyone done this and which mount did you use? My SE suggesting using the W1 wall mount to accomplish this. This will work but I was curious if there were other ways.
    Thanks!
  • 2.  RE: Mounting AP-220s and AP-320s to unistrut.
    Posted Oct 21, 2015 01:17 PM
    That can work, usually you can find a few ubolts, or make your own (with bolts and plate), to thread through the mount's srew holes over the unistrut. You can also look at the W2 mount, where you secure the mount to the unistrut, and then the AP will snap-loc into the W2 mount.
    Maybe others have example photos if what they have done.
  • 3.  RE: Mounting AP-220s and AP-320s to unistrut.
    Posted Oct 21, 2015 02:23 PM
    Awesome thanks for the quick reply. That's what I was looking to confirm.
