Mounting options for AP 225
  • 1.  Mounting options for AP 225
    Posted Oct 28, 2015 01:32 PM
    Good Afternoon Airheads,
         I'm looking for some advice regarding mounting an AP 225.  I'm replacing an existing Cisco AP and the the mounting location is on the underside of a steel I-beam/girder in a warehouse environment about 30 ft in the air.  All I have been able to find officially is the wall mounting kit when what I believe I need is more of a mounting plate and clamps of some sort.  Just looking for some direction from folks who may have dones something like this before to see what they used.
    Bill Fischer
    Versatile Inc.
    #AP225
  • 2.  RE: Mounting options for AP 225
    Posted Oct 28, 2015 02:49 PM
    I have used the wall mount bracket (AP-220-MNT-W1) in a steel beam using self tapper screws. Mounted to both wall and ceiling.
  • 3.  RE: Mounting options for AP 225
    Posted Oct 28, 2015 09:15 PM
    You can consider using a standard Aruba mount kit with standard "C"/Beam clamps.   Such as Granger 3KF30 to mount it to the I-Beam.
  • 4.  RE: Mounting options for AP 225
    Posted Oct 29, 2015 10:29 AM
  • 5.  RE: Mounting options for AP 225
    Posted Nov 03, 2015 01:45 PM
    Thanks very much.  This is going to work perfectly.
  • 6.  RE: Mounting options for AP 225
    Posted May 05, 2017 12:25 PM
    Is that an AP enclosure?  If so, what is the model/part number?
  • 7.  RE: Mounting options for AP 225
    Posted Aug 30, 2018 03:40 PM
    What type of screws did you use with the C beam clamps on the plastic mount kit?
