I have a two Access Points connected to a Controller(8.5.0.1) which is managed by a Virtual Mobility Master. I need to move the client connected to one access point to the other AP using a RSSI value. I have tried using the command arm move-sta <client-mac> <newbssid> . But the client doesnot move to the new BSSID.
Check to make sure the target bssid appears in the client's beacon report: https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/1cli-commands/sh-ap-vir-beac.htm?Highlight=virtual-beacon-report
Will I get output for this command only when a client is connected?
When I execute the command I get this output(Image attached).Now there is no client associated to the AP.
Kindly help me with this.
You should run that command with the client mac address on the MD.
Please see the thread here: https://community.arubanetworks.com/t5/Wireless-Access/Force-5-Ghz-for-a-specific-client/td-p/244052
I'm also having the same issue. Kindly someone help me with this.
Sachin,
We cannot help you without details.
