Move a Folder
  • 1.  Move a Folder
    Posted Mar 01, 2012 10:25 AM
    We'd like to change our Airwave folders from a flat system where they all reside under "Top" to a hierarchical system that more closely represents our organization. Is there a way to do move and rename folders in Airwave 7.3.5? I'm not finding it.
    Troy
  • 2.  RE: Move a Folder
    Posted Mar 01, 2012 11:04 AM
    I assume you have something like this now:
    Top
    - Folder1
    - Folder2
    - Folder3
    And you want to do something like this:
    Top
    - NewFolder1
      - Folder1
      - Folder2
    - NewFolder2
      - Folder3
    If that's what you need to do you can do the following:
    - Go to "APs/Devices" tab
    - Create the new folder structure you want from the "APs/Devices" (at the bottom of the page is "Add New Folder" link
    - Select the folder you want from "Go to Folder" selection at the top
    - At the bottom of the page there is a modify link (pencil)
    - On the screen that comes up, select the new Top folder
    Repeat the above to accomplish a restructure of your flat folders.  If this is not what you want to do, let me know.
    -Mike
  • 3.  RE: Move a Folder
    Posted Mar 02, 2012 09:04 AM
    That's it, thanks Mike!
