Moving AIPs+VC to another IP subnet
  • 1.  Moving AIPs+VC to another IP subnet
    Posted Sep 21, 2016 04:17 AM
    can someone give me the steps or best-practices for moving IAPs + their VC to a different subnet (we're migrating a customer) ? I have searched this forum but the only thing that pops up is a VC on a different subnet.
    The customer has an Airwave 8 server for managing the VCs and IAPs.
    Marcel Tempelman.
  • 2.  RE: Moving AIPs+VC to another IP subnet
    Posted Sep 21, 2016 05:49 AM
    You should just be able to move the IAPs to a different subnet.  You might have to change the Virtual Controller IP Address when you do, however to match the subnet.  Besides that, the IAPs will come up and if they get their addresses via DHCP, they will simply find the ip address of Airwave (which is hardcoded) and report where they are.  Again, you will have to change the Virtual IP Address so that things like Dynamic Radius Proxy work properly.
  • 3.  RE: Moving AIPs+VC to another IP subnet
    Posted Sep 22, 2016 10:44 AM
    Thank you for the reply. I am glad it is pretty straightforward.
    Marcel Tempelman.
