Moving CPPM from CP-HW-500 Platform to VM
  • 1.  Moving CPPM from CP-HW-500 Platform to VM
    Posted Jan 05, 2018 02:25 PM
    Wanting to move CPPM from CP-HW-500 platform to Hyper-V.  Are there any problems already known, I should be aware of?  Besides the Backup of the device, what other issues can I expect to run into?
  • 2.  RE: Moving CPPM from CP-HW-500 Platform to VM
    Posted Jan 05, 2018 02:28 PM
    What version are you running on the HW?
  • 3.  RE: Moving CPPM from CP-HW-500 Platform to VM
    Posted Jan 05, 2018 02:56 PM
    We are using 6.6.8.100017 for CPPM, I three in a cluster.  I already have been looking over the release notes for 6.7.  My devices will not handle the move unless I change to a VM.
  • 4.  RE: Moving CPPM from CP-HW-500 Platform to VM
    Posted Jan 05, 2018 03:04 PM
    A few things:
    - make sure that when you deploy your VM make sure is running 6.6.8 so you can do the backup/restore with no issues, then you can upgrade the VM instance to 6.7 (less downtime this way)
    - If any certificates were installed make sure to make sure to download the cert/private key since the certs are not included in the backup , also you need to know the private key password.
    - Add the VM instance to the domain.
    - I recommend you create a test SSID and make sure everything works before moving it over.
  • 5.  RE: Moving CPPM from CP-HW-500 Platform to VM
    Posted Jan 05, 2018 03:15 PM
    Victor,
    Thanks for the headz up!  Now since I have three devices in a cluster.  Can I run a dual setup until all the licenses are moved over to the VM.  Slowly moving licenses over or do I have to move over all at once?
