hello Airheads,
we have a V8 MM\MD set up running 8.7 code.
We have a MOXA AWK- 1137c set up in "client" mode this effectively means "work group bridge".
The MOXA wirelessly associates no problem but when we plug in a wired device into the ethernet port it does not get a DHCP address.
we have been round the houses trying to fix this and are considering a TAC case but thought i woud put this out there for input from
your good selves.
we have tried turning off "convert broadcast to unicast" under the VAP settings which hasn't helped and we are struggling with this combination
of MOXA client and Aruba. The MOXA associates fine to a home router and wired client all ok.
look forward to hearing from you.
pete
Pete Elms
