Mozilla 14 possible bug with Aruba Wizard
  • 1.  Mozilla 14 possible bug with Aruba Wizard
    Posted Aug 02, 2012 11:08 AM
    Okay i have tried this in 3 different machines
    3 machines with firefox 14
    1 machine with firefox 5
    On firefox 14 this is what it happens
    When you using wlan wizard  you can see the menu of the steps you have to do or the steps you going through the wizard for example
    WLAN
    Fowarding mode
    etc
    etc
    When you reach the captive portal one when you click next instead of going to authentication server it jumps to the end and tells you the WLAN wizard is completed... and let say you click finish and finish again besides it jumps many options it wont save the changes you did...
    This does not happen on Mozilla 5 neither on internet explorer 9
    Anyone else saw this already?
  • 2.  RE: Mozilla 14 possible bug with Aruba Wizard
    Posted Aug 03, 2012 05:27 PM
    I'm not sure if this is related but I had a recent issue similar.  I have about 10 AP Groups created and I wanted to create a new one the other day so I did the WLAN wizard.  Went through the setup and everything seems fine, only to find out that the configuration was never applied.  I had do it manually which is not a problem but not sure why this is happenng.  I open a TAC case but they said they never seen the issue before.  I will try this with another browser to see if it's browser related and let you know.
    **Update: Works fine in IE9, issue with Firefox 14.
    -Mike
  • 3.  RE: Mozilla 14 possible bug with Aruba Wizard
    Posted Aug 03, 2012 06:41 PM
    yep i know... but the problem is with just mozilla 14
    Then who should i report this bug? to aruba? or mozilla? hahha
  • 4.  RE: Mozilla 14 possible bug with Aruba Wizard
    Posted Aug 03, 2012 07:14 PM
    Lol.  Well, Aruba is aware of it and will log it.
    -Mike
