Comware
MPLS-TE on H3C CLOUD LAB
  • 1.  MPLS-TE on H3C CLOUD LAB
    Posted Mar 04, 2019 07:42 AM
    First, i apologize for my english.
    On the simulator i try to make a mpls-te tunnel like the exemple on the "HP MSR2000/3000/4000 router series MPLS configuration guide V7" on page 72 (Establishing an inter-AS MPLS TE tunnel with RSVP-TE).
    My netwok is ok about OSPF and BGP. The ip routing table confirm that.
    But when i configure the tunnel, the network i would to reach don't pass by the tunnel. On the Ip routing table is again learn by ospf
    Did someone succed to doing a inter-AS MPLS-TE ?
    Tanks
    #mpls
  • 2.  RE: MPLS-TE on H3C CLOUD LAB
    Posted Mar 25, 2019 03:19 AM
    Hello ,
    As per my undestanding ton your network the traffic should pass inside the tunnel -- Correct me if i am wrong . Can you please share us the configuration which you have made  .
    JMPK
  • 3.  RE: MPLS-TE on H3C CLOUD LAB
    Posted Jun 21, 2019 05:25 AM
    first i apologize for  the delay of my answer.
    In the example given in the documentation wich a refer on my last message. My network has to pass trough the tunnel mpls-te to join another network.
    Documentation here : https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c02659399
    <ROUTER A>di cu
     version 7.1.075, Alpha 7571
     sysname ROUTER A
    ospf 1
     area 0.0.0.0
      network 1.1.1.9 0.0.0.0
      network 10.1.1.0 0.0.0.255
      mpls te enable
     mpls lsr-id 1.1.1.9
     system-working-mode standard
     xbar load-single
     password-recovery enable
     lpu-type f-series
    vlan 1
    mpls ldp
     lsr-id 1.1.1.9
    mpls te
    explicit-path atod
     nexthop index 1 10.1.1.2 include loose
     nexthop index 101 20.1.1.2 include loose
     nexthop index 201 30.1.1.2 include loose
    rsvp
    interface Serial1/0
    interface Serial2/0
    interface Serial3/0
    interface Serial4/0
    interface NULL0
    interface LoopBack0
     ip address 1.1.1.9 255.255.255.255
    interface GigabitEthernet0/0
     port link-mode route
     combo enable copper
    interface GigabitEthernet0/1
     combo enable copper
     ip address 10.1.1.1 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     mpls te max-link-bandwidth 10000
     mpls te max-reservable-bandwidth 5000
    interface GigabitEthernet0/2
     combo enable copper
    interface GigabitEthernet5/0
     combo enable copper
    interface GigabitEthernet5/1
     combo enable copper
    interface GigabitEthernet6/0
     combo enable copper
    interface GigabitEthernet6/1
     combo enable copper
    interface Tunnel1 mode mpls-te
     ip address 7.1.1.1 255.255.255.0
     mpls te bandwidth ct0 2000
     mpls te path preference 5 explicit-path atod
     destination 4.4.4.9
     scheduler logfile size 16
    line class aux
     user-role network-operator
    line class console
     user-role network-admin
    line class tty
    line class vty
    line aux 0
    line con 0
    line vty 0 63
     ip route-static 30.1.1.0 24 Tunnel1 preference 1
    domain name system
     domain default enable system
    role name level-0
     description Predefined level-0 role
    role name level-1
     description Predefined level-1 role
    role name level-2
     description Predefined level-2 role
    role name level-3
     description Predefined level-3 role
    role name level-4
     description Predefined level-4 role
    role name level-5
     description Predefined level-5 role
    role name level-6
     description Predefined level-6 role
    role name level-7
     description Predefined level-7 role
    role name level-8
     description Predefined level-8 role
    role name level-9
     description Predefined level-9 role
    role name level-10
     description Predefined level-10 role
    role name level-11
     description Predefined level-11 role
    role name level-12
     description Predefined level-12 role
    role name level-13
     description Predefined level-13 role
    role name level-14
     description Predefined level-14 role
    user-group system
    return
    <ROUTER B>di cu
     sysname ROUTER B
    ospf 1
     import-route direct
     import-route bgp
     area 0.0.0.0
      network 2.2.2.9 0.0.0.0
      mpls te enable
     mpls lsr-id 2.2.2.9
     xbar load-single
     lpu-type f-series
    vlan 1
    mpls ldp
     lsr-id 2.2.2.9
    mpls te
    rsvp
    interface Serial1/0
    interface Serial2/0
    interface Serial3/0
    interface Serial4/0
    interface NULL0
    interface LoopBack0
     ip address 2.2.2.9 255.255.255.255
     combo enable copper
     combo enable copper
     ip address 10.1.1.2 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     rsvp enable
     combo enable copper
     combo enable copper
     ip address 20.1.1.1 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     rsvp enable
     rsvp hello enable
     combo enable copper
     combo enable copper
     combo enable copper
    bgp 100
     peer 20.1.1.2 as-number 200
     address-family ipv4 unicast
      import-route direct
      import-route ospf 1
      peer 20.1.1.2 enable
    line class aux
    line class console
    line class tty
    line class vty
    line aux 0
    line con 0
    line vty 0 63
    domain name system
    role name level-0
    role name level-1
    role name level-2
    role name level-3
    role name level-4
    role name level-5
    role name level-6
    role name level-7
    role name level-8
    role name level-9
    role name level-10
    role name level-11
    role name level-12
    role name level-13
    role name level-14
    user-group system
    return
    <ROUTER C>di cu
     sysname ROUTER C
    ospf 1
     import-route direct
     import-route bgp
     area 0.0.0.0
      network 3.3.3.9 0.0.0.0
      network 30.1.1.0 0.0.0.255
      mpls te enable
     mpls lsr-id 3.3.3.9
     xbar load-single
     lpu-type f-series
    vlan 1
    mpls ldp
     lsr-id 3.3.3.9
    mpls te
    rsvp
    interface Serial1/0
    interface Serial2/0
    interface Serial3/0
    interface Serial4/0
    interface NULL0
    interface LoopBack0
     ip address 3.3.3.9 255.255.255.255
     combo enable copper
     combo enable copper
     ip address 30.1.1.1 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     combo enable copper
     combo enable copper
     ip address 20.1.1.2 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     rsvp enable
     combo enable copper
     combo enable copper
     combo enable copper
    bgp 200
     peer 20.1.1.1 as-number 100
      import-route direct
      import-route ospf 1
      peer 20.1.1.1 enable
    line class aux
    line class console
    line class tty
    line class vty
    line aux 0
    line con 0
    line vty 0 63
    domain name system
    role name level-0
    role name level-1
    role name level-2
    role name level-3
    role name level-4
    role name level-5
    role name level-6
    role name level-7
    role name level-8
    role name level-9
    role name level-10
    role name level-11
    role name level-12
    role name level-13
    role name level-14
    user-group system
    return
    <ROUTER D>di cu
     sysname ROUTER D
    ospf 1
     area 0.0.0.0
      network 4.4.4.9 0.0.0.0
      mpls te enable
     mpls lsr-id 4.4.4.9
     xbar load-single
     lpu-type f-series
    vlan 1
    mpls ldp
     lsr-id 4.4.4.9
    mpls te
    rsvp
    interface Serial1/0
    interface Serial2/0
    interface Serial3/0
    interface Serial4/0
    interface NULL0
    interface LoopBack0
     ip address 4.4.4.9 255.255.255.255
     combo enable copper
     combo enable copper
     ip address 30.1.1.2 255.255.255.0
     mpls enable
     mpls ldp enable
     mpls te enable
     rsvp enable
     rsvp hello enable
     combo enable copper
     combo enable copper
     rsvp hello enable
     combo enable copper
     combo enable copper
     combo enable copper
    line class aux
    line class console
    line class tty
    line class vty
    line aux 0
    line con 0
    line vty 0 63
    domain name system
    role name level-0
    role name level-1
    role name level-2
    role name level-3
    role name level-4
    role name level-5
    role name level-6
    role name level-7
    role name level-8
    role name level-9
    role name level-10
    role name level-11
    role name level-12
    role name level-13
    role name level-14
    user-group system
    return
