MPSK Local - Possible bug
  • 1.  MPSK Local - Possible bug
    Posted Nov 15, 2020 10:45 PM
    Hi all
    Have come across a possible bug in using MPSK with OS 8.7.1
    From what I can see if a space is used in either the User Name or Role then the authentication fails.
    Anyone else come across this?
    Nick Perry
  • 2.  RE: MPSK Local - Possible bug
    Posted Nov 16, 2020 03:00 AM
    If you feel there is a bug, please reach out to Aruba Support so they can replicate and file a report to get the issue resolved.
    The use of spaces and special characters like &%$,@";<> are good to avoid in configuration and usernames; but if you found an issue please report to support.
    If you have urgent issues, always contact your Aruba partner, distributor or Aruba TAC Support. Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
