MPSK Passphrase
This thread has been viewed 30 times
  • 1.  MPSK Passphrase
    Posted Jul 27, 2022 03:34 AM
    I am testing MPSK on Clearpass & AOS and we want to implement specific MPSK per group of devices for IOT instead of per device MPSK.
    This scenario work OK with some changes on the MPSK Template generated service & policies.
    I have a problem if I want to set the Attribute "Aruba-MPSK-Passphrase", the only choice available is auto generated PSK as display below.
    The field is not editable !!
    Is there any way to set the Passphrase to a specific value instead of an auto generated value ?
    Kind regards
    Christian
  • 2.  RE: MPSK Passphrase
    Posted Jul 27, 2022 03:35 AM
    I am running CPPM 6.10.6
    Regards
  • 3.  RE: MPSK Passphrase
    Posted Jul 27, 2022 08:25 AM
    What may work is to export the config (with password!) then change the value in XML and import again. That should work.
  • 4.  RE: MPSK Passphrase
    Posted Jul 27, 2022 11:10 AM
    Hello Herman,
    As usual your solutions / workarounds are working like a charm.
    Tested and working :-)  Insert & update from XML permit to set the group PSK to a specific value
    Thanks and kind regards
    Christian
