MPSK Question
  • 1.  MPSK Question
    Posted 25 days ago
    I have a fast question regarding this.
    Does it allow just one device per password or many device can log in with the same password
    What I want to know if its a one to one password or I can log in with on password for example all my cameras log In with this password and all my printers log in with this one something like that.
  • 2.  RE: MPSK Question
    Posted 24 days ago
    You can use as many devices as needed with each password.
  • 3.  RE: MPSK Question
    Posted 24 days ago
    With MPSK WLAN, the preshared key is not stored locally in the controller, but is sent as a radius VSA from the ClearPass to the controller. Your enforcement profile only needs to send back the correct value, so both are possible.
    You can use a dedicated key for each device. In this case, you save it in the guest device and reference it in the enforcement profile with "Radius:Aruba Aruba-MPSK-Passphrase = %{Authorization:[Guest Device Repository]:Device MPSK}".
    Alternatively, use one key per device type/device guest role. In this case, you set the key in the enforcement profile "Radius:Aruba Aruba-MPSK-Passphrase = aruba123". The ClearPass GUI does not allow you to select a value yourself, one is generated automatically. If you want to use your own key, export the enforcement profile to XML, set your own key and import the profile.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 4.  RE: MPSK Question
    Posted 23 days ago
    Which MPSK?  There are a few implementations depending on version of AOS.
    MPSK Local (Instant and AOS 10) doesn't require MAC address registration.
    Carson Hulcher, ACEX#110
  • 5.  RE: MPSK Question
    Posted 5 days ago
    hello eveyone thanks for the asnwer
    Chelcher it on central  with a gateway, they have a clearpass as well.  They are doing it one way but i was advising them to we could change it with MPSK
