MPSK without Clearpass
This thread has been viewed 99 times
  • 1.  MPSK without Clearpass
    Posted Sep 01, 2019 07:31 AM
    is there any way to get MPSK working without Clearpass? We are working with FreeRADIUS (where we can configure custom attributes) and do not plan to use Clearpass in the future.
  • 2.  RE: MPSK without Clearpass
    Posted Sep 01, 2019 06:39 PM
    No, Clearpass is a requirement for Aruba MPSK.
  • 3.  RE: MPSK without Clearpass
    Posted Sep 02, 2019 07:12 AM
    Really?
    Isn´t MPSK on the Radius side not much more than sending a VSA to the controller that has the PSK for the client?
    Aruba-mPSK-Passphrase seems to be the VSA name.
    https://github.com/FreeRADIUS/freeradius-server/blob/master/share/dictionary/radius/dictionary.aruba
    has it.
    Christian
  • 4.  RE: MPSK without Clearpass
    Posted Sep 04, 2019 11:29 AM
    CPPM is required to support Aruba MPSK.
  • 5.  RE: MPSK without Clearpass
    Posted Sep 04, 2019 11:32 AM
    May I ask why?
    Couldn´t I setup freeRadius in a way that it will send back the mPSK on a per device/group basis?
    Controller will do a MAC auth against freeRadius and freeRadius can add the VSA when it is set back to the controller?
  • 6.  RE: MPSK without Clearpass
    Posted Sep 09, 2019 05:37 AM
    I would also like to know why I am not allowed to use a different Auth-Server for this.
    It seems I cant't configure MPSK with a FreeRADIUS Server, it simply recieves no requests when configuring it as a MPSK Auth-Server.
  • 7.  RE: MPSK without Clearpass
    Posted Sep 09, 2019 07:17 AM
    OK, we now got FreeRadius talking to our controllers. We are setting the correct "Aruba-MPSK-Passphrase" VSA, but the controllers are still complaining that it is missing ("Aruba-MPSK-Passphrase VSA not received for MPSK user - MAC cc:2f:xx:xx:xx").
  • 8.  RE: MPSK without Clearpass
    Posted Sep 09, 2019 08:04 AM
    OK, i found out how the VSA has to be used to get MPSK working without CPPM. I will write up how to do this in a blog post in a few days.
  • 9.  RE: MPSK without Clearpass
    Posted Sep 09, 2019 08:11 AM
    While this may work, it is not TAC supported.
  • 10.  RE: MPSK without Clearpass
    Posted Apr 13, 2021 11:36 AM
    May I please know how could you set up the MPSK without the CPPM?
    Many thanks,
    Ed
    Edward Zeng
  • 11.  RE: MPSK without Clearpass
    Posted Apr 14, 2021 09:24 AM
    https://www.arubanetworks.com/techdocs/Instant_87_WebHelp/Content/instant-ug/wlan-ssid-conf/conf-secur-sett.htm#Local
    You need to be on Instant 8.7 or up for Local MPSK.
  • 12.  RE: MPSK without Clearpass
    Posted Aug 28, 2022 11:59 AM
    Did you ever write the blogpost? If so, can you send a link?
    Nathan K
