MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
  • 1.  MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
    Posted 29 days ago
    Hi
    We're facing some issue regarding to our AD, it said that AD status {Device Timeout}
    We tried to re-join the AD to our ClearPass and it works but after several minutes the the Error 216 is back.
    Can someone explain to us why our AD is like this?
    Thank you.
  • 2.  RE: MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
    Posted 29 days ago
    What is this service? WLAN? Wired? Admin access?
    What is the client? Configured security?
    Does this happen for all of your clients?
    If you rejoin ClearPass to your domain does it work initially (you mention error is back after a few minutes)?
    It may be from this information that you use PEAP-MSCHAPv2. Be informed that there are know security issues with MSCHAPv2 and the protocol should not be used anymore. Migration to EAP-TLS or TEAP would be recommended. This does not answer your question, but think it's important that you are aware.
  • 3.  RE: MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
    Posted 28 days ago
    Hi Herman,
    What is this service? WLAN? Wired? Admin access? - this service is WLAN
    What is the client? Configured security? Users Laptop
    Does this happen for all of your clients? yes it happens to all the clients.
    If you rejoin ClearPass to your domain does it work initially (you mention error is back after a few minutes)? yes after we rejoin the AD to ClearPass it is working properly but after a few minutes and try to reconnect the client, it REJECT and the ALERTS shows that AD status {Device Timeout}
    So should I remove the PEAP-MSCHAPv2 then?
    Kindly see screenshots below for reference.
    connected time: 15:25
    Disconnected Time with the ALERTS AD status {Device Timeout}:15:58
  • 4.  RE: MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
    Posted 28 days ago
    Hi
    How many domain controllers do you have?
    Are they placed on different IP subnets?
    As you are using MSchapv2 ClearPass will try to find the closest domain controller with a DNS request, for this to work the subnet(s) where your ClearPass servers are placed must be added to a site in Active Directory Sites and Services.
    Ports must also be opened to allow traffic from to the domain controllers on all the RPC ports.
    I ha e seen a similar error where ClearPass tried to communicate with a remote domain controller where port ope ings where missing.
    Also add the domain controllers under Password Servers setting under the domain join.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
