MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
  • 1.  MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 03:46 AM
    Added the recent BADLOCK patch on CP 6.6 yesterday to a customer solution, and that stopped his EAP-PEAP authentications from going through - since it seems the AD trust was broken. We are now unable to re-join the domain.
    INFO - Using Administrator as the ****'s username Enter Administrator's password:
    Failed to join domain: failed to lookup DC info for domain '***.INT'
    over rpc: Access denied
    Working with Aruba TAC to solve this, but it's not a good situation to be in.. Google tells us that other have the same problems after applying the BADLOCK patch to their linux systems.
    So - halt your patching until this is worked out.. Has anyone else done this with success??
  • 2.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 03:54 AM
    Doesn't sound good! Will test it out in my lab and post back.
    #AirheadsMobile
  • 3.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 04:37 AM
    I patched my CPPM and it appears to be fine. EAP-PEAP auths are working ok too. Am able to browse AD from the LDAP browser. No problems here.
  • 4.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 05:17 AM
    Seems customer had disabled a couple of profiles in AD that caused this to happen:
    Microsoft Network Server: Digitally Sign Communications (Always)
    Microsoft Network Server: Digitally Sign Communications (If Client Agrees)
    I'm guessing this was disabled after joining Domain the first time, and as a result the trust wasn't re-established after the hotfix was applied.. Once these was enabled again we could re-join Domain and all was well.
    Solved - thanks Aruba TAC!
  • 5.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 05:39 AM
    jsolb,
    Which profiles?
  • 6.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Jun 02, 2016 06:47 AM
    Customer says they disabled these 7-8 years back to allow Mac's onto their domain..
    Seems that now they are required. Pretty sure I haven't seen that documented in the "Clearpass failed to join Domain" thread ;)
  • 7.  RE: MSCHAPv2 failing - unable to re-join AD after BADLOCK hotfix 6.6.0
    Posted Dec 19, 2016 12:31 AM
    Ran into the same issue after upgrading to 6.5.7. Solution was to add "client ipc signing = auto "  line in "smb.conf" file using Aruba support account.
    For more info: https://www.samba.org/samba/security/CVE-2016-2115.html
    Kudos to TAC.
