Hi, My current environment consists of 7 autonomous MSM430 and 1 autonomous MSM460 APs with the same SSID, WPA2 preshared key
Roaming between APs is bad, and since we heavily use RDP, the RDP connection goes grey until the new AP association occurs.
I got a MSM710 Mobility controller to test with, because in the product features was listed "Advanced fast roaming with VoWLAN support"
Now I cant tell with my 1 MSM430 and 1 MSM710 Mobility I have here at home if roaming will be seamless. And the fact that in VSC setup the fast roaming option is really opportunistic key caching, which is only available with WPA dynamic Key source (enterprise) makes me apprehensive.
Will the MSM710 mobility facilitate seamless (very fast, very fast RDP recovery) with a WPA2 PSK scheme?
#710#roaming#psk
