We have recently switched to EAP-TTLS as outer 802.1X authentication protocol for our campus wide MSM422 installation (controlled by a MSM765 zl, everything running FW 6.4.2.0-19648), and the problem we are seeing is that EVERY (reproduced with 3 different APs) MSM422 sends multiple EAP-Request Identity packets within a few thousands of a second.
This confuses the Windows 802.1x supplicant and thus the TLS handshake fails.
Just for the sake of completness, we are using a proprietary EAP protocol (EAP-JUAC) as inner authentication protocol. However, the issue described here occurs before the inner EAP method is even suggested.
Attached please find a packet capture that shows the problem.
Now the question is: Is this a bug? If not, why are the APs behaving this way?
Why would an AP send 3 ID requests a few thousandths of a second apart, is there a practical use case for this? Is there no way to instruct the APs to only send 1 as is common?
#MSM765zl#requestidenditypacket#EAP-TTLS#MSM422
