MSM460 with internal LAN and guest internet access
  • 1.  MSM460 with internal LAN and guest internet access
    Posted Jun 26, 2012 02:14 AM
    Can anyone provide configuration examples here? Apart from having 2 separate SSID on different VLANs is it possible to have 1 SSID hold 2 VLANs and have the RADIUS move users to the appropriate VLAN?
  • 2.  RE: MSM460 with internal LAN and guest internet access
    Posted Jul 08, 2012 07:53 AM
    Yes it is possible to do so, you need to create vlan range in the controller assign that to the "VSC binding", then make sure the APs ports are tagged in those VLANs, you have to test it since i'm not sure in this case you need Mobility Traffic Manager or it will work without it (should work unless HP has restrictions to use MTM)
  • 3.  RE: MSM460 with internal LAN and guest internet access
    Posted Jul 17, 2012 10:06 AM
    You can do that with non-access-control VSC. You can assign users to different VLANs (Tunnel-Medium-Type, Tunnel-Private-Group-ID, andTunnel-Type) from RADIUS, then tagged the switch port where the AP is connected to handle those VLANS. You can also do that by enabling MTM, but each VLAN must be created at the controller and assigned to a port.
    .Lmm
    #Radius
    #VLAN
    #msm
    #VSC
